Temp Gauge Problem
Old Apr 26, 2005 | 03:34 PM
aboobybobpleez's Avatar
aboobybobpleez
Certified Rice-Rocket
Default Temp Gauge Problem
Well my car has been doin this the past few days. When my car is warm and im sitting at a light right when i stop the gauge is normal, a little before halfway, then about 5 seconds later my needle raises to about 3/4 and right when i start to move the gauge drops to normal? coolant levels are good and everything
Old Apr 26, 2005 | 03:36 PM
Co0lDood's Avatar
Co0lDood
[ATP]ATL
you sure you dont have a vaccume leaks?
Old Apr 26, 2005 | 03:44 PM
dubcac's Avatar
dubcac
I
You may have air in the system. Bleed the coolant system. Do your fans come on at all?
Old Apr 26, 2005 | 06:59 PM
coltank's Avatar
coltank
Has your car overheated at all lately? And you said you have not had to add any fluid to it?
Old Apr 26, 2005 | 07:52 PM
aboobybobpleez
no it hasnt overheated and everything has been running normal...it seems to do it more when im doin stop/go city driving
Old Apr 27, 2005 | 06:41 AM
coltank's Avatar
coltank
Well, I was having a similar problem with mine, and it turned out I had a leaking hose. Without proper pressure to the system your fluid is not going to circulate, causing your overheating problems. The reason it would not be rising while driving is because you've got cool air entering into your engine bay to help regulate the temp of the engine
Old Apr 27, 2005 | 02:50 PM
dubcac's Avatar
dubcac
I
He said on AIM his fans don't turn on. Check the thermostat and fan relays.
