Help please
Old Apr 22, 2005 | 06:22 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
Default Help please
How do I pull the codes on my 95 GSR?? Please help!!!
This is what happen, I had an exhaust made yesterday and they removed the cat. Cel comes on at start up, but if I turn the car off and back on once it is warmed up, it goes away....
O2 maybe??
PLEASE HELP A NOOB OUT!!!!
Old Apr 22, 2005 | 06:55 AM
'93TurboD's Avatar
'93TurboD
5-finger discount :rick:
I beleive all OBD1 hondas use the same method to check CEL's try this thread here... https://www.honda-acura.net/forums/s...d.php?t=185065
It's even got a video showing you how. Also check the Integra FAQ thread in this forum, and the online resources thread in the civic/del-sol/el forum for info.
Once you know the code post it up, and we'll take it from there..
Old Apr 22, 2005 | 07:12 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
I dont see the jumper plug anywhere?!?!
Old Apr 22, 2005 | 07:16 AM
'93TurboD's Avatar
'93TurboD
It should be in a green rubber thing with another connector in it. In the passenger side foot well, near the door.
Old Apr 22, 2005 | 07:23 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
I found it! The code is a 41. Does that mean I need to replace it?!?
Old Apr 22, 2005 | 07:50 AM
post what it says code41 is.
dont have a manual in front of me.
Old Apr 22, 2005 | 07:58 AM
'93TurboD's Avatar
'93TurboD
Code 41 is a heated O2 sensor problem. I could mean that the sensor is just un-plugged. Take a look at the connector for the O2, make sure it's not unplugged or wires falling out of the connector.
Pull the negative terminal from the battery for 30 seconds, to clear any codes. Then start her up and see if it comes back. If so go get a new NGK/NTK O2 sensor, or an OE one. Bosch may require you to rewire in your existing connector.
Old Apr 22, 2005 | 08:00 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
41 Primary oxygen sensor heater
