Check engine light?? Need Help
Old Apr 21, 2005 | 08:22 AM
anewsom's Avatar
anewsom
RoadRacer
Originally Posted by :snoopy:
i hope you dont plan to rev that high on a stock block.
Why you say that? I been told that the only worry is floating the valves, which I have taking care of with new springs.
Old Apr 21, 2005 | 12:57 PM
Snoopy's Avatar
Snoopy
been there done that
the rod bolts on the stock rods are a weakpoint if you plan to rev that high. at the least, have the rotating assembly balanced and get new rod bolts.
Old Apr 22, 2005 | 03:34 PM
Jed parel's Avatar
Jed parel
i was planning on getting a chiped computer made for my jrsc setup by sales@racingchips.com i found them on ebay are they any good? he said they can raise the revlimit set vtec point up 11psi on stock map full throtlle launch nos control advance timming all for about $300 with jumper harnesshttp://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7969675580&catego ry=33596 should i do this?
Old Apr 22, 2005 | 05:08 PM
Snoopy's Avatar
Snoopy
you're better off going with hondata. something actually tuneable.
Old Apr 22, 2005 | 05:19 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I agree.
Also if you raise the rev limit, you should balance the rotating assembly and replace rod bolts like snoopy said but you should also look into a girdle like the GSR has to keep the rotating assembly still under those higher revs. Unless you do those things, expect to blow that motor up very soon.
Old Apr 23, 2005 | 05:08 PM
civicandtegra's Avatar
civicandtegra
when it comes to major stuff dont be a cheapo buy a hondata,ebay stuff sucks,also pickup a manual for your car, its says i think for my 91 ls to run a wire on the ecu cant remeber where and a led will flash on the ecu (light is above check engine light on gen2 gsr) and the manual has the trouble codes or have a shop check it out if u not sure what to do
