IACV Cleaning...
Originally Posted by MaxOctane
Definitely not true. It really depends on the hose that is cracked. A cracked vacuum hose that causes a vacuum leak will definitely create a problem. A cracked heater hose will most likely cause a water leak and your car will overheat when you end up dumping all of your fluid. BUT, a crack in a breather hose, which connects to the intake BEFORE the throttlebody will not cause any problems. This is the hose which is shown in the pictures above. A crack in this hose will cause the breather gasses (air + oil-vapor) to escape into the air, and thus create a neglegent increase in polution. It will not create a vacuum leak because it connects to the intake BEFORE the throttlebody, nor will it create any other performance problems. A crack in almost any hose will create problems, a crack in this hose will not.
Well, on the way home from work tonight I got a CEL pop on... and I just checked it, code 74...
74 96-98 Civic
97-98 CRV
96-98 Prelude
94+ Integra
Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
How do I check to make sure all my cylinders are getting sparks? Im about to reset the ecu tho, and see how that goes...
74 96-98 Civic
97-98 CRV
96-98 Prelude
94+ Integra
Try resetting the ECU, since you didn't have the code before. Occasionally I'll get a misfire code on startup, but it's just a random misfire...ECU reset clears it.
As for your idle problem, I'd check for vacuum leaks and your IACV. The PCV has no affect on idle.
Well, I checked the iacv already and cleaned it... but it still does it, so I think it may be a vacuum leak? Also, my car kinda like sputters when accelerating and wont go anywhere, then it will clear up and run fine... it does it randomly but often enough to be aggravating.
Ahhh, also, I noticed that something under my hood "clicks". It constantly clicks and when I get closer to it I believe it may be the alternator? It is coming directly from the left side of the engine, right next to the valvecover, just south from the oil cap cover.
first off misfires has to do with ignition, so reset the ecu yes, whens the last time you got a tune up? have you pulled the plugs to look at them? I had a badly gapped plug that caused me to have a fumbling idle. Check the basics.
Was the IACV stuck when you took it out? Does it open and close properly? I agree with checking plugs as well, but I think bad idles caused by faulty ignition components would be apparent at cold engine temps as well. Since it only happens when the engine is warm, I think it's the IACV still. Do you have a known good IACV you can swap in...from a friend or something?
No, not at the moment I dont... heh... I dont know anyone in my area with an integra yet...
What do you mean does it open and close properly? there was nothing to open or close that I saw when i was looking at it... there are two holes, one has a screen on it and the other is just an opening...
