replaced missing CEL bulb, checked codes
Old Apr 6, 2005 | 01:47 PM
R_Squared's Avatar
R_Squared
LEVEL UP
Default replaced missing CEL bulb, checked codes
Ok, so I finally pulled out my gauge cluster to see what was up with the check engine light because it had never come on. Ever. Sure enough, the bulb was missing! The guy I bought the car from was really sneaky. Anyway, so I got a replacement bulb, jumped the wires and checked for the codes. As long as I did it right, I believe I got codes:
1 - Defective or Unplugged 02 Sensor
10 - Defective or Unplugged IAT (Intake Air Temp) Sensor
41 - Primary 02 Sensor heater circuit malfunction
So where should I go from here? I mean, I already knew the IAT sensor was messed up because the black piece that it hooks into on top of the manifold is broken, so it never clicked all the way into place. But what does the sensor not being hooked up actually mean as far as how the car runs? Is this something that urgently needs to be replaced? And what about the O2 sensor and the related heater circuit malfunction? What should I do? Thanks in advance for any help with this stuff.
Old Apr 7, 2005 | 01:12 PM
R_Squared's Avatar
R_Squared
LEVEL UP
I am probably going to replace my 02 sensor this weekend, but which one do I need to get. I know I only need one since I am Obd1, but I mean can I just get a bosch universal, or do I have to get OEM or what?
Old Apr 7, 2005 | 08:00 PM
carta79's Avatar
carta79
Life after death
You would have to wire up a Bosch universal o2 sensor by reusing your stock harness. (Unless something has changed without my knowledge) NGK/NTK O2 sensors come with the correct harness I believe. Both Bosh and NGK make quality parts, it's up to you. Fix the primary and IAT sensors and you should be good to go.
Old Apr 7, 2005 | 08:14 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You can also get a used OEM sensor from www.sohfast.com. The one I got from them a few years ago is still working great.
Old Apr 8, 2005 | 03:11 PM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
Go OEM, the bosch and other aftermarket O2's are not calibrated like the OEM replacements.
The O2 could just be unplugged. It's very possible since the circuit heater code and the O2 code could come on if you leave it unplugged.
Old Apr 8, 2005 | 05:05 PM
R_Squared's Avatar
R_Squared
LEVEL UP
Ok thanks, I will check it out this weekend. Could this be a big reason why I am getting such poor gas mileage? Like 21-23 mpg with easy driving...
Old Apr 8, 2005 | 05:21 PM
dubcac's Avatar
dubcac
I
Bad O2 sensors can cause poor gas mileage for sure.
