Turbo is 75% in!!!!!!!!! =)
Old Apr 3, 2005 | 06:42 PM
  #41
newgsrdriver's Avatar
newgsrdriver
Where did you get that fitting? The block/sender is BSPT and the feed line is NPT. If you try to screw in a standard NPT fitting in the block, it will strip it. You need to get the right fitting from fast-turbo or stealthmode or somewhere if you havent already.
And as someone mentioned above, bigger certainly is not better with IC's. Just like turbochargers, there is a proper size for specific setups.
Old Apr 3, 2005 | 07:19 PM
  #42
honura's Avatar
honura
Seni
Im gonna go to sears and get the tap for it tomm and hopefully I can fix it.
