Yellowing Headlight Plastic
Old Apr 2, 2005 | 10:40 AM
Kai's Avatar
Kai
Rotorphile.
I use Blue magic products with great success.
Old Jun 1, 2005 | 01:51 PM
will94integ's Avatar
will94integ
Two months later, how did your blue magic & never dull work? Have you had to re-apply since early April? I need to do something about my headlamps lenses also.
Old Jun 1, 2005 | 02:45 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
My personal writeup:
https://www.honda-acura.net/forums/s...d.php?t=186050
Old Jun 1, 2005 | 04:17 PM
Tobra's Avatar
Tobra
After you get it clear, try putting the vinyl covers on the plastic lenses, clear stuff that you just lay on there, I don't believe they are adhesive. It will protect against rock chips/cracks and also blocks UV light. My buddy put them on his prelude, and it worked pretty well.
Old Jun 1, 2005 | 08:28 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
Shmoo's write up works like a charm :thumbup:
Old Jun 1, 2005 | 10:38 PM
Provocateur
On permanent hiatus
Thanks man.
I actually stole someone's idea off another site but I couldn't find it again, so I made my own. h:
Old Jun 1, 2005 | 11:26 PM
GSR4444's Avatar
GSR4444
or just start to pretend that your going for that jdm "amber"
Old Jun 3, 2005 | 11:04 AM
will94integ
Default yellowing headlights
How long did your headlights stay clear? or how long between applications? Trying to decide whether it's worth it to use the nevr-dull or go through the trouble of sanding the lenses. Thx.
Old Jun 3, 2005 | 11:22 AM
Provocateur
On permanent hiatus
The never dull stuff is only $3.50 a can and there is enough to polish hundreds of headlights. Mine are still clear but if they turn yellow again, it only takes 2 minutes to bring them back.
I would recommend against sanding them.
Old Jun 3, 2005 | 12:03 PM
Schwa's Avatar
Schwa
Schiggity
Shmoo, nice write up but in the picture you put microfiber on the ground...thats bad.
That never dull stuff just seems like a fine compound and then you buff it out with the MF.
