anybdy have problems removing the crank pully bolt?
Life after death
Originally Posted by MaxOctane
easier said than done. I have the helm manual for the car so I know how much to tighten it. Also, the manual speaks nothing of this tool.
Originally Posted by carta79
Holder Handle 07JAB-001020A
Pulley Holder attachment 07MAB-PY3010A
HEX 50mm, OFFSET
Socket, 19 mm
07JAA-001020A
Commercially Available
HEX 50mm, OFFSET
Socket, 19 mm
07JAA-001020A
WHAT OK YEAH!
Note:
Crankshaft pully bolt size and torque value:
14X1.25 mm
177 N.m (18.0 kgf.m, 130 lbf*ft)
When installing a new crankshaft and/or new pulley bolt:
1. Tighten the pulley bolt to 196 N*m (20.0 kgf*m, 145 lbf*ft)
2. loosen the bolt
3. retighten it to 177 N*m (18.0 kgf*m, 130 lbf*ft).
*When installing the bolt, lubricate the threads with engine oil, but don't lubricate the washer and pulley.
When removing the crankshaft pulley bolt it would save you a big headache if you have the proper tools.
HEX 50mm, OFFSET
Socket, 19 mm
07JAA-001020A
Of course this info comes to late for you but will be available to others. :exnbp:
14X1.25 mm
2. loosen the bolt
HEX 50mm, OFFSET
Socket, 19 mm
07JAA-001020A
I had the same problem. I talked to the Acura Service guy so i had all the right tools. But I still had to light up the torch to get it out. I used an impact to no success. I was standing on a 3 foot breaker bar and it wouldnt even move, but when the heat came, she started to ease off.
This information was taken from a helms. For the crankpulley bolt it states these special tools for removal/replacement.
Life after death
You must have a helm manual for a newer year car. After double and triple checking the 91 integra manual it speaks nothing of that tool. I guess it was published before they realized that removing that bolt might be a problem?
Heck...... I got a 550ft lbs impact gun... stuck a 19mm impact socket on it..... sprayed PB blaster on the crank pulley bolt and let it soak while i went to drag my air compressor from the garage to the driveway... plugged in and cranked up the compressor to about 140psi........ plugged in the impact gun.... then wham, took it right off no problems.
I hope you don't normally run your impact gun on 140psi. Most impact guns run on 90psi and running it higher will ruin, or severely decrease the life of the tool. Be nice to your tools, and they will be nice to you too......
Biggity bam:
http://www.moroso.com/catalog/catego...?CatCode=27115
Available through Summit and others. Better than and less expensive than the OEM tool. Also extremely heavy and potentially a lethal weapon.
