Clutch and tranny questions
Old Mar 12, 2005 | 07:14 PM
barcardi_blasta's Avatar
barcardi_blasta
Default Clutch and tranny questions
is it normal for a tranny to shift if its out a vehicle? Like you can push the shaft in and out the shift linkage connected to?
Engine B18b
Also, my pressure is low on the pedal of a 1994 Honda civic HB, fluid is high, so does this mean i need a new master cylinder or slave cylinder?
Old Mar 13, 2005 | 05:03 PM
m735is's Avatar
m735is
I can always shift the tranny when it's out of the car.
I got a low pedal pressure when I changed out my slave cylider. I tried to bleed it thinking the effort would increase. It didn't. Now I'm used to it. The two clutch sets I've replaced since then haven't changed it either. I don't have any problems shifting, so it must be good.
Are you having touble with shifting?
Old Mar 14, 2005 | 06:29 AM
barcardi_blasta
Yeh, sometimes i had to slam it in till it shifted fine again.
