Integra burning oil?
Old Mar 9, 2005 | 08:56 AM
Buktheng's Avatar
Buktheng
Hello there!
Default Integra burning oil?
Usually on long drives my car (96 4dr GSR) tends to lose a lot of oil. I think its burning oil cause I don't see any leak on the ground. I do see some oil leak around the spark plug holes and some near where it says the block number. What do you think I can do to fix the problem? I'm tired of changing the oil and then like acouple weeks later, having to pour more oil in. Its a big waste of money.
Old Mar 12, 2005 | 03:31 AM
m735is's Avatar
m735is
If you're burning it, it could be valve seals or piston rings. The valve cover gasket may be leaking alittle. How much are you going through?
Old Mar 12, 2005 | 07:31 AM
2001TEGGSR's Avatar
2001TEGGSR
My 2001 GSR does the same thing with 38,000 Miles on it. I know its been covered several times, did you try searching?
