R Oil
Originally Posted by IdealConcepts
The guy asked how many miles I have on my car and I said 68K and he said it’s too late to switch over to full synthetic and that if I wanted to use full synthetic I should have done it at under 10,000 miles (couldn’t have because I didn’t get mine until it have 13K miles). Is this true
now to find out what the dealer has in terms of synthetic. Hopefully they have mobile 1. I'm pretty sure they have at least Castrol Full Synthetic.
Thanks bbasso, not to find out what the dealer has in terms of synthetic. Hopefully they have mobile 1. I'm pretty sure they have at least Castrol Full Synthetic. Thanks again.
Are you going to let them change your oil? Why not DIY ? it's easy, fast and not messy. You don't even need a jack to lift the car. Just put one front wheel up on a curb
But if it's not your thing bring the oil you want to the dealer, they should not have any problems.
I tried it once after I had changed out the suspension and took forever. I have a 2.5 ton jack but its too high to fit under the car, I have to use the jack from the car, which takes a few mintues to take out because I have my sub box screwed into the car to keep it from sliding. I also get a little nervous being under the car when it's jacked up becasue it is so low. So I have the dealer do it, I do change the oil on my Toyota Truck. Don't have to jack the truck up.
