Do most of you guys just get 2 new front tires instead of all 4?
Good post obsidian.
Want to get power to the ground? Best tires up front.
Want to stop sooner? Best tires up front.
As mentioned earlier, if you rotate your tires frequently, you shouldnt have this 2 or 4 tire issue. I replace all 4 at once, and theyre usually all 4 equally dogged.
Working on project CRX Si
Originally Posted by Vanishing
In front wheel drive cars it is recommended to have your two tires with the most traction mounted on the rear.
Originally Posted by Shmoo
There is no reason you should be doing e-brake turns when you know your tires are bald in the first place, or anywhere on the street for that matter.
When you stop hard, the car's weight shifts towards the front, pressing the front wheels down & giving them better traction. The rears get un-weighted, & if you're going around a curve at the time, it'll oversteer badly - quickly, too. (Trailing-throttle oversteer.)
If the rear tires are close to the same condition as the front it's OK. If the rears are much worse, it happens earlier, more suddenly, & it's difficult to recover from this.
Any taildragger pilots out there? I think ground-loops would be a better example.
On permanent hiatus
I understand where you are coming from now. You do have a very good point but I would rather go into oversteer than understeer any day and with the baldies on the front, an understeer is more likely to happen.
