Burning Oil?
Old Feb 27, 2005 | 11:25 AM
midwestgsr's Avatar
midwestgsr
Default Burning Oil?
Hey, I have a 97 integra gsr and i think i may be burning oil. when i stomp on the gas a lot of carbon comes out of my exh. some people said that i was probably just running really rich, but i don't know if that is the case.
does anyone know what would cause a 97 integra to burn oil? any suggestions?
seals? damaged engine? does anyone know what is probably causing this, and how much it will cost to get fixed?
BTW, the car has like 97K miles, and I don't drive hard at all.
Thanks
Old Feb 27, 2005 | 11:36 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
I had the same problem. Turns out it was the piston rings. It would send a puff of smoke out the exhaust whenever the throttle was mashed. I had to replace the rings and since I did, there hasn't been any burning at all.
Old Feb 27, 2005 | 11:37 AM
midwestgsr's Avatar
midwestgsr
ok, do you know how much a shop would charge to replace them?
Old Feb 27, 2005 | 11:38 AM
Provocateur
On permanent hiatus
I did it myself but I heard that the Acura dealership will charge about $900 for the service.
Old Feb 27, 2005 | 11:41 AM
midwestgsr's Avatar
midwestgsr
Damn. that really sux. i wish i didn't have 2 left hands and could get under there and do it myself.... how long did that work take? what did the parts cost?
Old Feb 27, 2005 | 11:42 AM
Provocateur
On permanent hiatus
About 10 hours total with help from my girlfriend. The parts ran me about $350. It was a bitch of a job and I hope I never have to do it again.
Old Feb 28, 2005 | 11:18 AM
Snoopy's Avatar
Snoopy
been there done that
is the smoke black or white/blueish?
Old Feb 28, 2005 | 11:51 AM
MaxOctane's Avatar
MaxOctane
it really depends on the color of the smoke. Is it blackish smoke, or is it white with a tint of blueish?
Old Feb 28, 2005 | 03:46 PM
midwestgsr's Avatar
midwestgsr
that i don't really know...the blueish is oil, but i think it is buring oil because i have to keep adding and there are no leaks.... do you suggest piston rings as well?
Old Feb 28, 2005 | 08:48 PM
Provocateur
On permanent hiatus
My smoke was a little black and a little blue. I know it was running rich but being 3 quarts low a month after an oil change suggests something is really wrong. If you do decide to do the piston rings, I suggest you also replace the valve seals since the head is off anyway.
