Axle strippd and wont come out
My friend stripped my axle while changing the clutch. (using a metal nose hammer to get my axle out, compressed the threads). i told him not to but... he insisted it wouldn't do shit. now im in a dilema of changing my axle. so since that thread was compressed, the 32mm nut that goes on the tip of the axle was not on. so i drove my car, my only source of transportation. now i have to swap the old one out. the old one will not seem to budge now, im thinking the teeth of the axle mending together with the brake teeth. i've tried everything from a metal nosed hammer, mallot, and some impact jack hammer tool. tried prying it and everything. what are my other options?
oh yea i've soaked it with WD40
Your Powder Coater
Air Chisel (sp?) with the point on the end.. have at it.. not good to be driving on it without proper assembly... which you have now learned the hard way.. good luck.
yea i used the air chisel, i had to drive it because my shop teacher wouldnt let me leave my car there. and i had to get around, somehow. today im gonna try the object that goes diagonally across 2 lug nuts and in the center is the axle tip where u tighten 2 bolts on the lugs and eventually pushes out the axle tip. i dont know what its called but. yea.
anymore ideas?
anymore ideas?
Your Powder Coater
anymore ideas?
anymore ideas?
yea... i have an idea that is garenteed to work.. but it's costly..
it's called a torch.. keep cuttin till it's all off, then replace everything that u just ****ed up!
