Suspension Techniques or Type R sway??
Old Feb 9, 2005 | 05:42 PM
meangreen96's Avatar
meangreen96
Integra Owner No. 122,019
Default Suspension Techniques or Type R sway??
The suspension techniques has a 25.4 mm front bar and a 19mm rear.
Close to stock but with more rigity
Or!!! should I just get the front bar from suspension techniques
and use the 22mm rear bar. I don't want to much over steer though. I like the car balanced and I do already have pretty stiff rear shocks.
anyone with suspension techniques...........big difference?
input input!
Old Feb 9, 2005 | 07:44 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
id go with JDM itr fronts and USDM rears
Old Feb 9, 2005 | 09:20 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
Keep your stock front swaybar (24mm) and get the itr rear. Should still be pretty neutral. I'm running no front sway bar and 22mm rear comptech, little tricky but nothing too bad.
Old Feb 9, 2005 | 09:34 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Get the comptech swaybar. I have it and love it. It is also adjustable, so if you find you don't have enough oversteer you can tighten it. I left my front one stock, because if you get a bigger one, it will just cancel out the effect of the rear one.
Old Feb 9, 2005 | 10:07 PM
hakjai's Avatar
hakjai
i second that
Old Feb 10, 2005 | 02:20 AM
BONE's Avatar
BONE
Get the ITR rear sway bar it should be cheaper than the ST one also dont forget to get either the beaks or bsq reinforcement kit.
