acura integra LS -95
Old Feb 6, 2005 | 03:54 PM
frankcomp's Avatar
frankcomp
Default acura integra LS -95
I have a 95 acura integra LS. The car has never given me any problems, up until a week ago, I was driving and the car just stalled on me. I checked everything. The problem is it is not getting any spark to the spark plugs from the distributor. I changed the distributor cap and rotor. It still won't start. It sounds like it wants to, but it doesn't. Anyone have any idea what I should do?
Old Feb 6, 2005 | 03:56 PM
j87w's Avatar
j87w
You may have a bad ignition coil. Just a guess though. Its inside the dizzy.
Old Feb 6, 2005 | 04:34 PM
teg92's Avatar
teg92
WHAT OK YEAH!
i would defently check the ignition coil happend to my friend on his GSR. Replaced it and it worked
Old Feb 6, 2005 | 05:10 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
Yup! :chuckles:
Old Feb 8, 2005 | 08:00 AM
95tegRS's Avatar
95tegRS
grab a new distributor assembly. comes with everythig u need. 3 bolts to install it. Should take you less than 10 mins.
its a common problem. since the coil is inside the distributor, it gets subjected to tons of heat, and heat is what kills them in the long run.
