Need help to beat WRX fast!
Old Feb 3, 2005 | 07:48 PM
RboYi's Avatar
RboYi
hey.. does anyone know what 1/4 time 9.8 for the 1/8 would be for a GSR?
what is the stock 1/8 for the GSR?
Old Feb 3, 2005 | 07:59 PM
dubcac's Avatar
dubcac
I
You're in the mid 15's.
Old Feb 3, 2005 | 08:25 PM
RboYi's Avatar
RboYi
i ran a 10.1 1/8 and got a 15.5
so wouldnt a 9.8 atleast be 15.2?
Old Feb 3, 2005 | 09:28 PM
LudeRage's Avatar
LudeRage
Nitrous is a good idea, especially considering you already have the clutch. I ran 1.4 seconds faster at the track with a ZEX 55 shot (dry) over all motor. It was a bad day, and my best all motor was only 15.8, but with the 55 shot I managed an awesome run of 14.45 in the 1/4 (and a 9.25 1/8 mile). On a better day I would have been pushing 13's. So just think of what your car will do with a 75 shot. My friend with a GSR swapped Civic EX actually has my ZEX kit now, and with the 55 shot he's high 13s (he also has a CAI, DC 4-1, 2.5" exhaust, and suspension).
Anyways, hopefully you have some skill driving. Are you going to primarily race in the 1/4 or 1/8? That's a huge difference, because some cars can do great down low for example and dont have a lot of top end...for example, I could beat you in the 1/8 but you should edge me out in the 1/4. Take that into consideration when picking certain mods (for example for the 1/8 I would go with the 4-2-1 and for the 1/4 the 4-1).
I have 2 friends with GSR's; one has a 4-2-1 header and 2.25" exhaust; one has a 4-1 and 2.5" exhaust. The first one beats on the second one until the second one starts pulling like crazy at around 80 and passes him. The first one is faster in the 1/8; the second faster in the 1/4.
Again I would go with a dry nitrous kit; I really liked my ZEX kit, simple to install/use and very effective. You will own him even with just a 55 shot, but your car can easily take a 75 shot if you retard the timing a few degrees. Good luck!
Old Feb 4, 2005 | 05:49 AM
Running925's Avatar
Running925
Your Powder Coater
I would also recommend the Zex kit if you choose to go the nitrous route. I had one on my stock D16z6 & it was a world of a difference!! Only thing i did was upgrade my fuel system a little bit so that i could run the 75shot. I went through 5 bottle's (10lb) & had no troubles with my motor. Zex all the way!
Old Feb 4, 2005 | 03:59 PM
dubcac's Avatar
dubcac
I
I recommend the Zex kit as well, and it's what I use. Anything 75 shot and under, it's the best kit on the market...tried and true. Just make sure you tune it correctly and use the right plugs.
Old Feb 7, 2005 | 06:12 PM
RboYi's Avatar
RboYi
alright, right now i have enough money for cams, i heard BLOX cams were the same as SKunk2, manufactured in the same place n everything. Does anyone want to confirm this? Does this go for the Intake Manifold too?
