Help!!! I think i blew my engine...
Old Jan 28, 2005 | 10:07 PM
nvd13ymost's Avatar
nvd13ymost
Default Help!!! I think i blew my engine...
Hey whats up people, i think i blew my engine... ok this is what happend... while driving i was in fourth gear around 8000 rpm and when i went to shift to 5th gear... i got mistaken and dropped it to 3rd... my engine did a nasty sound and my car turned off... I pulled to the side and tried to turn it back on and nothing... i had the car towed to my house. i took of the valve cover to see if everything looks right from the top and everything was fine... Now some people have told me that i might of have bent the valves badly. I need sum opinions of what should i do... by the way i have a itr jdm motor
Old Jan 29, 2005 | 03:07 AM
JMcDB18C's Avatar
JMcDB18C
JDMB18CIntegra
Hey man, I have a 96 JDM Spec R too. It sounds like your timing blew. You said your car just shut off, no power?? Sounds like you couold have bent the valves really bad. Is your timing belt in tact? Check out your water pump pulley and and all that stuff down that way. Take your head off too if you dont see anything around the timing area. Let me know. Sounds like timing though. Later.
Jonathan
Old Jan 29, 2005 | 07:55 AM
nvd13ymost's Avatar
nvd13ymost
Thanks for replying man, but yea i took off the valve cover last night and the timing belt looks fine... i will try to take the head out to check it out today... If i did bent my valves, would you know how much would it cost to rebuild the head?
Old Jan 29, 2005 | 01:15 PM
pUrExTc's Avatar
pUrExTc
殺生丸
it's quiet a costly endeavor...
...i was racing on the freeway (yeah, we all did it in our youth), and shifted to a lower gear (too low) and i saw my tach jump to past 9000 RPM. Immediately i pushed in the clutch, and put it up a gear. i got lucky, i think, coz nothing happened.
Old Jan 29, 2005 | 01:24 PM
nvd13ymost's Avatar
nvd13ymost
Thats exactly what happend to me, i stepped on the clutch right away... but it still turned off.
Old Jan 29, 2005 | 02:21 PM
bbasso's Avatar
bbasso
Take out your spark plugs and look inside each combustion chamber, Your looking to see if any of the piston tops have unusual markings or bits and pieces of anything.
If you see anything odd, Very bad.
IF you don't then you might have gotton away with just bending valves. But either way looks like you will have to pull the head off.
Old Jan 29, 2005 | 03:45 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
ouch!
good luck man
hope its not gonna cost u too much
Old Jan 30, 2005 | 05:12 PM
JMcDB18C's Avatar
JMcDB18C
JDMB18CIntegra
Well If you want valves I have a set of Skunk2 Valves brand new in the box that I would be able to sell you, Later
jon
Old Jan 30, 2005 | 09:39 PM
damn that sucks...things i was going to say to check have been psoted so yeah.
my friends type R went from 8K RPM to pass the 10K limit on his guage...and yeah... he got lucky though it still worked afterwards , hopefully u are too
Old Jan 31, 2005 | 07:42 PM
oldskoolcivic's Avatar
oldskoolcivic
sounds like u need to rebuild the engine for good measures... just take off the whole damn block and inspect everything, cause u dont want to like replace the valves and not see if theres any internal damage, like rods, crank, pistons, rings, etc. but yea i had that happened to me before, i was bumpin my subs hella loud on the freeway when i needed to pass this truck.. after almost passing it, i was at 4th at about 4k rpm (70 mph) and needed to shift to 5th, but with the music hella loud and my habits of slammin the clutch, gasssin it hard, shift, and let go of the clutch fast, i accidently hit 3rd. luckily my engine went to about 8500 rpm and i hit the clutch fast enough to save it. the clutch burned up hella bad
