getting into my gauges
Old Jan 18, 2005 | 08:31 PM
integsr's Avatar
integsr
Default getting into my gauges
how do i get into my gauges to put some blue lights behind the needle? Can anyone recomend a book that shows me how to get into the gauges? or explain it
Old Jan 20, 2005 | 10:04 AM
riderintegragsr's Avatar
riderintegragsr
riderintegragsr
Default guages answer
on my car(2000 gsr)..... there are two screws on the top as you look in... tilt your steering wheel all the way down....then just pull it out....after that there should be about 3-4 more screws holding your gauges in. it should pull right out and there are wires that just plug into back.. the lights u turn and pull out. mine were already blue on mine.
Old Jan 20, 2005 | 10:08 AM
BONE's Avatar
BONE
I was going to say the same thing.
Old Jan 20, 2005 | 11:37 AM
GSRchick714's Avatar
GSRchick714
Ditto. And my lights were already blue also.
Old Jan 24, 2005 | 01:14 PM
nbuehler's Avatar
nbuehler
nb
Yeah, I was going to do blue, but the blue just appears white. I replaced with red instead, but it's not that great. now it doesn't match the rest of my center dash console, although I could replace those too. I'd just stick with the white/blue.
Old Jan 25, 2005 | 02:28 PM
escrayzee's Avatar
escrayzee
my friend and i both did this (not with integras but it doesn't really matter) and his turned out WAY better 'cause he used 194 Blue LEDs instead of what i used (194 blue incandescent). The ones i chose seem more teal (when lit) but the LEDs are like bright blue.
Old Jan 25, 2005 | 03:42 PM
Dreadful's Avatar
Dreadful
I'm trying to do this on my 92 integra GS
not just to my guages but anything that lights up on the inside...
im running into a hell of a lot of problems here...
first i found out that red bulbs werent avialable, so i tried to paint them instead with heat resistant glass stain... but it wouldnt stick to the bulbs!
then i tried to paint the casing instead (i tried it first on my rear defrost button just to test it out and see if it would work) and the paint mixed with the glue and ruined the symbol!
i had to go buy another button for 15$!
so now my dash is all apart and ive got nothing to show for it yet...
any suggestions?
