Driving with a Cel 67
Old Jan 16, 2005 | 06:22 PM
OilCanBoyd's Avatar
OilCanBoyd
Default Driving with a Cel 67
My check engine light has been on for a while. It is a 67 on my 98 GSR. I took it to my shop and they hooked it up to the computer. It is the Cat Convertor. Not the sensors or anything. The actual cat. So they reset it and told me if it came back on I would need to replace it. Well it came back on.
I have been told an aftermarket cat will be around $300.
I don't feel like spending $300 on that part if it is not hurting my car. I don't like hurting the enviornmet either but I'd rather not pay $300 to get that check engine light off if its not hurting my car. Are there cheaper cats out there? Could I possibly find a used one and stick it on? Any suggestions? I see $15 dollar things on ebay but I'm guessing that is just a straight pipe.
Thanks
Old Jan 16, 2005 | 06:29 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
CEL codes: http://www.c-speedracing.com/faq/05.php
#67: Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
It can cause the engine to run poorly and change the fuel efficiency. Check at a junk yard for another one. They will be cheaper there. Also, try www.sohfast.com.
hih man
Old Jan 16, 2005 | 09:55 PM
96GrnGSR's Avatar
96GrnGSR
$300 for a new cat?! is it the oem cat or aftermarket? i can get it for way cheaper than that, but then again, i work @ a mechanic shop
Old Jan 17, 2005 | 04:56 AM
carta79's Avatar
carta79
Life after death
$300 for an aftermarket cat, who fed you that bs. You can get a good high flow cat made by Magnaflow for much less than that.
Old Jan 17, 2005 | 08:33 AM
OilCanBoyd's Avatar
OilCanBoyd
My local shop. Tell me where to buy a cheap high flow cat. I am all ears!
Old Jan 17, 2005 | 08:49 AM
VPUPPY's Avatar
VPUPPY
try www.haprecycling.com. they are a honda parts recycling place in cali, they may have it for a good price used.
Old Jan 17, 2005 | 09:41 AM
carta79's Avatar
carta79
Life after death
Click me
I just got a carsound high flow cat with prewelded flanges for $150.00. How much can you spend?
Old Jan 17, 2005 | 10:11 AM
OilCanBoyd's Avatar
OilCanBoyd
$150 would be fine!
Originally Posted by carta79
Click me
Old Jan 17, 2005 | 10:54 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
Is it bad if you don't have an O2 sensor connected?
Old Jan 17, 2005 | 11:24 AM
jjang's Avatar
jjang
i had a code 67 with my high flow cat but the light eventually went off (and my 2nd o2 sensor is disconnected, guys at the speedshop said it wouldnt change anything since i had a code 67 already). recently the CEL came back on at WOT but whatever. im planning on getting a carsound cat soon, ebay has decent prices, less than $100 i believe. i dunno if the 2nd o2 sensor changes MPG's... i get 23 or so per gallon and its been that way since i put on the 18" wheels
