weird whistling noise?
Old Jan 15, 2005 | 09:28 PM
RboYi's Avatar
RboYi
Default weird whistling noise?
sup guys, i installed my spoon 9lb flywheel and exedy stage 1 clutch yesterday, didnt really complete the small stuff like tightening my cat convter bolts to my exhaust all the way because my time limit i had in school periods. so i drove it home. and when i drove it when i got up to 3k+ i heard a weird whislting noise that got louder, is it the lightened flywheel? thanks
Old Jan 15, 2005 | 09:36 PM
Jed parel's Avatar
Jed parel
well it could be the throw out bearing making noise, maybe not enough grease or to much and it cause it to harden
Old Jan 15, 2005 | 09:48 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
That is what I am thinking. Did you replace it or reuse the old one?
Old Jan 15, 2005 | 10:09 PM
dubcac's Avatar
dubcac
I
Does it only happen at light throttle? My CAI used to whistle at light throttle. It could be an exhaust leak, although it doesn't really sound like a whistle. I don't think the throwout bearing would whistle either. I have a lightweight flywheel, and mine didn't cause a whistling sound...neither did my bad throwout bearing.
Old Jan 15, 2005 | 10:25 PM
RboYi's Avatar
RboYi
yea the one step i forgot to do was use lithium grease on my throwout bearing.. did my shaft but not my bearing. well on my exhaust i only have 1 sprung bolt from the header to the cat and 2 of the 3 on the cat. to the exhaust. and they are only hand tightened, no tools at home!
Old Jan 15, 2005 | 10:34 PM
dubcac's Avatar
dubcac
I
You need all of the exhaust bolts. Both sprung bolts, and the 3 from the cat to the exhaust. I hope you made sure that the gaskets were still there.
Old Jan 15, 2005 | 11:14 PM
dom93hatch's Avatar
dom93hatch
more meat, more fire
I thought a bad throwout bearing would have a clicking sound. My clutch used to have a clicking sound... It's on and off now.
Old Jan 16, 2005 | 04:36 PM
Jed parel's Avatar
Jed parel
well i also have a light flywheel (spoon) and i did not put any grease and it started to make noise like a whistle sound and when i put grease it was fine what it is, is that the bearing is rubbing on the teeth of the pressure plate
