Intake Question
Old Jan 13, 2005 | 03:18 PM
BlakIzBak728's Avatar
BlakIzBak728
Default Intake Question
Does anyone know where i can buy a cai for my 1998 teg with a bypass valve already installed?? I live in Fl, and with all the hurricanes I dont want to risk gettin hydrolock or whatever its called. Also i really dont trust myself with having to cut the pipe in order to install the valve.
Old Jan 13, 2005 | 03:32 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
i dont know anywhere you can buy a CAI with a bypass valve already installed unless you buy it from someone.
Old Jan 13, 2005 | 03:59 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Whassup? Welcome to HAN.
IMO the typical CAI is overrated. An Icebox would be a worry free way to go, and you'll see comparable gains if not better, when compared to a regular CAI.
Old Jan 13, 2005 | 04:11 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
and they eliminate the chances for hydrolock.
Old Jan 13, 2005 | 09:43 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
They do. But if you want a CAI with a bypass valve already installed, I would suggest searching for a used one off ebay.
Old Jan 13, 2005 | 09:59 PM
brothalynchhung's Avatar
brothalynchhung
or get a hood with hood scoop with a latch u can close when it rains and use short ram =P
Old Jan 14, 2005 | 11:38 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Seriously though, if you've got your heart set on a CAI w/ a bypass valve, then any shop that carries the AEM line of intakes can set you up. The bypass valve is sold separately, and you'd install it between the lower and upper pipe sections when you install the AEM CAI. It's not a challenging installation.
As others have said before, a non-sealed cold air duct to the OEM airbox (or a short ram intake) is the safest way to go.
And welcome to HAN. :cheers:
Old Jan 14, 2005 | 12:13 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
every AEM CAI ive had was always one piece :thinking:
Old Jan 14, 2005 | 12:52 PM
TheOtherDave™
Apathy Kills
h: Just checked..you're right, I'm wrong.
It's the V2 system that's 2 piece..
At any rate, cutting the intake takes about 30 seconds with a hacksaw. IMHO, that's not exactly something to worry about screwing up. Just be sure to clean out any remaining metal filings on the cut ends.
Old Jan 14, 2005 | 01:09 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
yes i knew i was right!
