Squeeky rear end
Old Jan 12, 2005 | 01:25 PM
Dedalus2k's Avatar
Dedalus2k
Default Squeeky rear end
I've got this rubbery sounding squeek coming from the hatch compartment and I can't nail down where it's coming from. I even had my girlfriend ride in the trunk to try and track it down. Has anyone else had this issue and if so what might it be?
Old Jan 12, 2005 | 01:45 PM
LT's Avatar
LT
The deer had to die!
over time those rubber stoppers on the underside of that hatch will compress. their "height" can be adjusted by turned it counter-clockwise.
if that doesn't work, try greasing the d-hook that locks into the hatch release mechanism.
Old Jan 12, 2005 | 02:37 PM
Dedalus2k's Avatar
Dedalus2k
Thanks...I'll give that a shot.
Old Jan 12, 2005 | 07:29 PM
newgsrdriver's Avatar
newgsrdriver
Totally, try that, and also try wrapping the latch on the hatch with some electrical tape so it closes tighter.
Old Jan 12, 2005 | 08:03 PM
Singhg83's Avatar
Singhg83
BALLIN'
:werd:
did that like 2 years ago, and still is pretty quiet.
Old Jan 13, 2005 | 05:13 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
The rubbery balloon chewing sound could be bushings from a camber kit if you have it or bushings in general (usually aftermarket), you can lube those no problem. Try what the others said for the hatch, if it is still there...checked for screws on hose clamps that may be rubbing against something metal under the hood. I had that noise for a while and I could not track it down for shit. I thought it was coming from anywhere in the car as I could not pinpoint it. Finally i found it on accident and just turned the screw, problem solved.
Old Jan 13, 2005 | 06:34 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
:werd: i was going to say his bushings might be shot thats why they're squeeking.
Old Jan 15, 2005 | 04:09 PM
jr_kbad's Avatar
jr_kbad
could be your bumper coming loose. mine came loose and started squeaking like crazy! annoyed the heck out of me till i finally found it what it was.
Old Jan 15, 2005 | 07:52 PM
Dedalus2k's Avatar
Dedalus2k
It was the rubber pads....thanks man!
-LT69Padawan6
Old Jan 15, 2005 | 10:07 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
my car makes a lot of noise too in the back, its probably cause i have the backseats out so i heard every little thing
