Low Compression in cylinders..
Old Jan 12, 2005 | 08:13 AM
jame5x's Avatar
jame5x
Default Low Compression in cylinders..
I drive a 95 integra ls and I checked the compressions of all four of my cylinders because it was running like crap.
1st-120 2nd-125 3rd-120 4th-140
Is this at normal compression? I was kinda thinking they're way too low.
How do i fix this? Change the head gasket?
Is changing the head gasket easy?...costly at the shop?
HELP!!
Thanks
Old Jan 12, 2005 | 01:13 PM
dubcac's Avatar
dubcac
I
It seems a little low, but they are all close together. If you really wanted to fix the problem, you could take apart the bottom end and put new piston rings in...but that would be an expensive labor job.
Old Jan 12, 2005 | 06:13 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
That and replace the valve seals.
Old Jan 12, 2005 | 07:12 PM
jamesmeister's Avatar
jamesmeister
if you wanted to swap rings, you'd also have to yank the head, which I just did on my car. It is not fun. those numbers dont sound TOO bad....i wouldnt worry yet about compression.
Old Jan 12, 2005 | 09:23 PM
j87w's Avatar
j87w
Mine were all in low the low 160 range on my LS. It has 85K on it.
