help! jdm b18c swap no spark
Old Jan 9, 2005 | 05:32 AM
jtracing919's Avatar
jtracing919
Default help! jdm b18c swap no spark
i just swapped a obd1 b18c 5 speed into my 95 rs auto. i used my original engine harness and wired vtec, knock sensor, and aib to ecu. i have switched out the coil and icm from my b18b. i have 9 volts coming from yel/grn signal wire to icm and i have 12 volts at the 3 other connections on the icm. there is also 12 volts to coil. i still have no spark. is there some differnce in the jdm motor or am i missing something else? the engine turns over fine, the plugs are wet with fuel. no spark
please help
Old Jan 9, 2005 | 05:54 AM
teg92's Avatar
teg92
WHAT OK YEAH!
check your dizzy? Make sure all your grounds have a good connection and re-check your wiring
Old Jan 9, 2005 | 06:47 AM
jtracing919
i checked the grounds on the thermostat housing and the one 1 on the front of the head, are there any others i am missing, also is there any thing also that i can check in my distributor?
Old Jan 9, 2005 | 07:06 AM
JMcDB18C's Avatar
JMcDB18C
JDMB18CIntegra
CHECK ALL GROUNDS!!!! Does it turn over for a sec and then just shut off? Im thinking its a ground man. Grounds is the answer to all lifes swaps!!
Jon
Old Jan 9, 2005 | 07:15 AM
jtracing919
it turns over fine. i can't remember if i hooked up the ground on the tranny, though. also it wouldn't have anything to do with jdm motor not having an ELD?
Old Jan 9, 2005 | 10:28 AM
dubcac's Avatar
dubcac
I
Are you using a USDM or JDM ECU? The USDM ECU would look for an ELD, but I don't know if that would cause it to not start...probably just throw a CEL. Definitely check and recheck all of your grounds. Did you do anything else before the swap maintenance wise...like a timing belt?
Old Jan 10, 2005 | 11:45 AM
jtracing919
i haven't done anything except change the oil. i am using the p72 ecu that came with the engine. I think i am not getting a proper signal from the ecu at the yel/ grn signal wire
Old Jan 10, 2005 | 12:21 PM
jtracing919
does the ecu send a signal to the icm, or does it open and close a ground to make the coil fire?
