96' GSR with 96' Spec R swap.......help
I was looking into getting the AEM EMS this week and I was fooling around with my ECU and I noticed that whenever i swapped my JDM 96' Spec R motor into my 96' GSR a year or so ago...That the type R ECU P73 has 4 slots for plugs and the GS-R only has 3 plugs and I have an open port in my ECU. Now...the car has run fine no problems. I have headers and intake and straight pipe through exhaust...no cat, and I dyno-ed @181 whp. Is this normal? Could something not be going right because of that missing plug in the port? Or should I look into getting a conversion harness?? All help on this subject would be greatful. Thanks.
Jon
Jon
It was on a Mobile chasis dyno, dynojet. How did you dyno@ 170whp on a dynojet?? I wouldnt think that I/H/E would give you a 25hp increase? I know GS-R dyno @ 170 bhp but Thats cool that you pumped that much.
So having that missing port in my ECU is not causing anything? So If I get the AEM EMS and I plug it in like it is now with that missing port it will be fine? thanks
jon
jon
Originally Posted by centerforce99
I read the power pages once in Import Tuner and they bumped a stock GSR to 168 w/an I/H/E set-up. Surprisingly the GSR only loses about 12hp to the wheels under a load.
