Gsr Engine VS. LS engine (what are the diffs)
Old Dec 25, 2004 | 05:41 PM
j87w's Avatar
j87w
Default Gsr Engine VS. LS engine (what are the diffs)
My question is what exactly different from a gsr engine to an ls. I know the LS has a lower output water and oil pump, the crank is not zero balanced, the stroke is up like 1.6mm, the rods and rod bolts are not as strong, LS has no oil squirters, and no crank girdle. So how balanced is the LS engine. Also is there any other differences that I didnt put down. Any differences anyone wants to put would be appreciated. Thanks J
Old Dec 26, 2004 | 01:19 AM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
http://www.team-integra.net/section...sp?ArticleID=43
Old Dec 26, 2004 | 09:05 AM
95tegRS's Avatar
95tegRS
LS's dont have Vtec cams, or Vtec solinoid
Old Dec 26, 2004 | 11:39 AM
ED9man's Avatar
ED9man
driver
The entire head is different
Old Dec 26, 2004 | 01:05 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The LS also doesn't have a knock sensor.
Old Dec 26, 2004 | 01:06 PM
j87w's Avatar
j87w
My bad I meant just the bottom end. I know the you cant bolt a VTEC head straight up to the LS, I know the LS dosent have the oil passage to the head. I just want to know whats the differences in the block not the head. Thanks though. I heard the gsr and type r bearings have a silicone overlay over them or something.
Old Dec 26, 2004 | 01:19 PM
Snoopy's Avatar
Snoopy
been there done that
a gsr block will have a block girdle
Old Dec 26, 2004 | 01:22 PM
Provocateur
On permanent hiatus
Thats right...totally forgot that. It is like a half-girdle.
Old Dec 26, 2004 | 01:28 PM
j87w's Avatar
j87w
I know the GSR has a girdle but are you saying the LS has a half-girdle or the GSR does? Also on the bearing part I think there teflon coated(vtec 1.8). Can anyone confirm on that?
Project_ITR's Avatar
Project_ITR
the GS-R motor (B18C) came in integra GS-R's, and the LS motor (B18B) came in integra LS...hope i cleared that up
