Very Sluggish Clutch Pedal / Cold Temps
98 GSR 90K. Temps around here have been very very cold! Is it normal for the clutch pedal to be very sluggish in this weather. After 10-20 minutes and the car heats up it seems to be fine. I have owned other 5 spds. (non integras) and never noticed this.
i got this too...any body kno the cause...also, when the car is very cold, i get a little grind when shifting gears...kinda like bad synchros...but it goes away when it is warm...any ideas??
thankyou
thankyou
Have your fluid flushed. the Acura dealer ( and may service stations) use a vaccume device to flush out the contaminents outta the hydrolic system, thus it wont be sluggish when you shift. IF your getting drinding, thats a real problem. You should change the fluid right away, if that doesnt solve your problem you have to change the clutch's master clyinder (id change both master and slave cylinder) the parts are cheap and it will shift like brand new again!!!>
GOod luck
GOod luck
On permanent hiatus
I notice this too. It isn't really cold here but if I don't let things warm up, they seem sluggish. Fluids have all been changed and flushed, so I guess it is normal.
