Help Bleeding Brakes
Old Dec 14, 2004 | 04:45 AM
toaster's Avatar
toaster
Default Help Bleeding Brakes
I replaced the rear calipers in my 93 integra and I can't get all the air out of the system. I don't have a manual. Is there an order for which caliper to do first, second, etc...?
My technique is just to have someone pump the pedal, hold the pedal down, then I open the bleed nipple.
Old Dec 14, 2004 | 06:05 AM
JimBlake's Avatar
JimBlake
I don't know the order for '93, but if you do the wrong order I think the only problem is you have to go around a couple times to get all the air out. So just keep going.
If you let it drain, plan on bleeding around a pint thru each rear caliper. It takes a while. Are you ONLY bleeding the rear? I've never been able to get away with that. Bleed all 4.
Old Dec 14, 2004 | 06:23 AM
Driver's Avatar
Driver
slow lane cruiser
The sequence may be different but on my 95 you bleed right rear, left front left rear, and right front (criss-cross pattern)
Old Dec 14, 2004 | 11:20 AM
Tobra's Avatar
Tobra
On my 98, it is RF, LF, RR, LR which seems totally wrong
Old Dec 14, 2004 | 12:20 PM
JimBlake's Avatar
JimBlake
You're probably both right. My '95 GSR is like Driver says, but my '98 Accord is like Tobra says. (Both per their Helm books.)
With ABS, the bleeding order is all about which circuit pushes air bubbles into which other circuit. That just depends on the plumbing details around the ABS unit, which changed between '97 & '98.
Old Dec 14, 2004 | 03:51 PM
BlaqueGhost's Avatar
BlaqueGhost
Rear Right Front Left Rear Left Front Right
thats what is in the manual for 90 - 93
Old Dec 15, 2004 | 05:02 AM
toaster's Avatar
toaster
Default Thanks!
Thanks for the help. I also learned that when you replace rear calipers they don't always adjust to take up the extra space between the pads and the disk, so you have to turn them out more (using a special tool) to take up the slack.
Old Dec 15, 2004 | 10:52 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
If you pump the brakes a bit, it should take up the slack...
