HELP Installing Different Gauge Clusters In Teg
Old Dec 12, 2004 | 10:10 PM
j87w's Avatar
j87w
Default HELP Installing Different Gauge Clusters In Teg
I want to install a JDM gauge cluster out of preferably a itr but some people say the wiring is different. On the auction like on ebay it says no wiring changes will work with 94-01 Teg. My teg is a 95 LS by the way. Can I use a gsr cluster or such.
Thanks for advice on my question.
Old Dec 13, 2004 | 08:27 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
Integras from 98+ had a different wiring layout for the cluster. If this cluster does not work you can always swap the guages between the two clusters. This is what I did to get a 97 ITR cluster to work in my 2000 GSR.
Old Dec 13, 2004 | 10:46 AM
j87w's Avatar
j87w
How do you swap them? Wont the needles be off? So I can use a 96 Spec ITR cluster on my 95 LS?
Old Dec 13, 2004 | 11:09 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
If you look at the cluster you will notice plastic clips all along the sides that hold the clear plastic cover on as well as the plastic bezel that surrounds the guages. You need to remove these. Then there are screws on the back of the cluster that hold the 4 guages in place. By removing these screws the guages will easily come out. Installation is the reverse. Be carefull not to touch the needles, if you do not touch them they will not be off.
Old Dec 13, 2004 | 06:07 PM
j87w's Avatar
j87w
So if I put the kph over my mph it will read kph accuratly?
Old Dec 14, 2004 | 07:54 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
You are not putting anything over anything. When you remove the guages by taking the screws out of the back the whole guage itself come out. You swap your MPH guage with the KPH guage, once you take it apart you will understand what I am talking about. This is actually a very easy thing to do.
