Jdm Itr Piston install in b18c1 require break-in?
if i were to install the jdm itr pistons in my 99 gsr woould a break in process be required..i was told by some yes because the rings need to reseat and others that no because its standard bore pistons..any input?
Before you start it, unplug the distributor and crank it over a bit to get oil pressure in the engine and get oil circulated. Then let it idle for a bit after you finish the ring/piston/bearing install to let the rings seat. After that, just drive it normally. A lot of documentation about no break in period has been put up on the web lately, and I agree with it 100%. Check this out http://www.importbuilders.com/breakin.html
There was another post on H-T I read a while back, and I actually heard about this theory a few years ago. The only break in I would ever do is for a clutch. If I was building a motor and going turbo, I'd let it idle to seat the rings, then tow it to the tuner and throw it on the dyno.
Make sure you lube it up before assembly with engine lube to make the inital startup less harsh. But you do need a few hundred miles of "easy" driving to make sure the bearings and rings seat correctly.
Originally Posted by Master Yodub
Actually the bearings require no break in period, they are good to go....and the rings seat in about 20 mins.
. My car= the fuxors
