Right Real wheel bearing
Old Dec 11, 2004 | 07:49 PM
brothalynchhung's Avatar
brothalynchhung
Default Right Real wheel bearing
How hard is it to replace a rear wheel bearing and a website showing how its done?? if anyone could help me out that'd be great, id rather pay 150 for the part and do it my self if its easy and not pay some guy 400 for it
thanks alot =))
Old Dec 11, 2004 | 11:15 PM
brothalynchhung
Another thing, iv was told this is a very rare bearing to go out most of the time its the front bearings, anyone else have this problem??
Old Dec 12, 2004 | 12:40 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
You need to remove the hub and have the old bearing pressed out with a hydraulic press. Then you need to get the new one pressed in with the hydraulic press. I would have someone else do it for you.
I haven't heard of the back bearings go out. How do you know it is bad?
Old Dec 12, 2004 | 07:57 AM
newgsrdriver's Avatar
newgsrdriver
The rear bearing is a hub/bearing unit in one piece, no press required. Take off the old hub replace with new and youre good to go.
They go out commonly on Integras, the rear bearings suck. You'll get a groan at speed that sounds like its coming from a corner, its typically easy to pinpoint. Get a Helms manual for step by step instructions.
Old Dec 12, 2004 | 10:13 AM
brothalynchhung
Hey thanks alot is it easy? have u done it?
Old Dec 12, 2004 | 01:35 PM
newgsrdriver
A couple times unfortunately. Its easy. The hardest things you will run into will be the rotor retaining screws, which I just drill out anyway. If you dont want to drill them out, lube them up and take an impact screwdriver to them.
Old Dec 12, 2004 | 09:57 PM
Provocateur
On permanent hiatus
Ok. I thought you were going to use the old hub and just get the old one pressed out.
Old Dec 13, 2004 | 10:49 AM
j87w's Avatar
j87w
How do you know when there out or there going out?
Thanks
Old Dec 14, 2004 | 05:56 PM
brothalynchhung
its howels whole driving
Old Oct 15, 2008 | 05:59 AM
jdmforeel's Avatar
jdmforeel
Originally Posted by newgsrdriver
the rear bearing is a hub/bearing unit in one piece, no press required. Take off the old hub replace with new and youre good to go.
They go out commonly on integras, the rear bearings suck. You'll get a groan at speed that sounds like its coming from a corner, its typically easy to pinpoint. Get a helms manual for step by step instructions.
how do you get the bearing out of the hub...i have this kind of problem and i have no i dea how to take the bearing out
