95 Integra ABS light comes on
Old Dec 3, 2004 | 01:49 PM
InSumNiaK's Avatar
InSumNiaK
Default 95 Integra ABS light comes on
Ive got a 95 integra and my ABS light comes on when I restart the car after
it has been running and will stay on. My ABS does not seem to be working at
all.
But on a cold start, everything is fine, the ABS light is off and the ABS work great.
Any idea what may be the problem or things I can try to fix this ?
I already added some brake fluid, but that doesn't seem to work.
Old Dec 3, 2004 | 02:05 PM
FunctionMotoring's Avatar
FunctionMotoring
HAN Approved Vendor
So, when you first start the car it will not come on..
If you drive around.. turn off the car, and start it back up, only then it turns on?
Old Dec 3, 2004 | 02:15 PM
InSumNiaK's Avatar
InSumNiaK
That's right.
Old Dec 3, 2004 | 02:24 PM
FunctionMotoring
HAN Approved Vendor
Originally Posted by InSumNiaK
That's right.
Ok, just looking through my Helm's manual. There is a huge trouble shooting list and steps you would need to follow..
I can start w/some simple items to check..
The first is to check the underhood fuse for ABS.. it's a 15A fuse. Check that out then get back to me.
Old Dec 3, 2004 | 02:47 PM
teg92's Avatar
teg92
WHAT OK YEAH!
would low brake fluid do that?
Old Dec 3, 2004 | 02:52 PM
FunctionMotoring
HAN Approved Vendor
Low brake fluid turns on the E-brake light..
He already checked his fluid level.
Old Dec 3, 2004 | 02:53 PM
InSumNiaK's Avatar
InSumNiaK
There's a box a fuse especially for the ABS unit under the hood.
There was one 10 A, one 20 A, one 15A and also one 40A.
All the fuses where OK.
Thx for the help
Old Dec 3, 2004 | 02:58 PM
FunctionMotoring
HAN Approved Vendor
Thx for the help
Hrm... There is a whole chapter in the Helms dedicated to Trouble Shooting the ABS system.
Looks like you'd need to get a code by counting the # of blinks from the ABS light for us to get anywhere. You have to do this by jumping the service connector.
It is located under the right hand side of the glove box. You'd have to jump it w/a paperclip like you do to get Check Engine Lights... You know how to do that right?
Also you can remove the 15A fuse you were talking about earlier to erase the ABS units memory and see if the light comes back. Make sure to leave it out for @least 3 seconds.
What kind of conditions have you been driving in... snowy/slick?
Old Dec 3, 2004 | 03:06 PM
InSumNiaK's Avatar
InSumNiaK
I'll check the code tomorrow morning.
While checking the underhood fuses, I needed to move the car just a bit. The engine was on about 1 1/2 minute.
The ABS light was off. I restart the car just after that, and the light was on.
I have the problem since last friday. It was a pretty cold day, there was no snow at all.
Since last friday, it happened once or two that the ABS light didn't come on after I restart my car.
Old Dec 3, 2004 | 03:18 PM
FunctionMotoring
HAN Approved Vendor
Strange how it's sporadic like that..
Check here before you count the blinks.. the ABS unit can store up to 3 error codes.. I'm going to post up info on how to count them properly in just a moment.
