is a knock sensor really needed
Old Oct 24, 2004 | 08:50 PM
j87w's Avatar
j87w
Default is a knock sensor really needed
Im going to do ls vtec just so whoever replys and reads this knows why im asking. But is it that necessary to have a knock sensor. It seems as if most of the reprogrammed ecus have no knock sensor inputs(honda data, katmans stuff). Anyone have any opinions?
Thanks
Old Oct 24, 2004 | 09:47 PM
dubcac's Avatar
dubcac
I
You don't need a knock sensor.
Old Oct 28, 2004 | 11:52 AM
trex_tegra's Avatar
trex_tegra
if u reprogram ur ecu with the hondata system i kno that u dont but not sure with other programs but with hondata u dont
Old Oct 28, 2004 | 03:11 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Knock sensors would not be _needed_ for your situation, with the proper tuning... but I have no idea if they're even installable on a LS/VTEC setup
Old Oct 28, 2004 | 07:56 PM
dubcac's Avatar
dubcac
I
They can be installed into the LS block if you really want to, but IMO it's not necessary. However, if you plan on running a GSR ECU, it will look for a knock sensor. Some aftermarket piggyback chips eliminate that.
Old Oct 29, 2004 | 03:57 AM
Katana950's Avatar
Katana950
AutoX-Acura
Without knock sensor a stock ecu will throw a fault code and immediately disable vtec, but a hondata unit can disable the need for a knock sensor, but with stock ecu might not vtec won't work.
Old Oct 29, 2004 | 09:04 AM
dubcac's Avatar
dubcac
I
Only if you're using a stock ECU that looks for a knock sensor.
