Radiator Replacement
Old Oct 24, 2004 | 12:59 PM
HYBRID's Avatar
HYBRID
Default Radiator Replacement
Does anyone have any good links to how to replace a radiator on 96 integra? thanks
Old Oct 24, 2004 | 01:17 PM
akid's Avatar
akid
it isn't that hard...all you have to do is remove the 3 tabs on top. then remove the fans. drain the fluid out, and disconnect the hoses. it should slide right out. then put the new radiator in. if you want pictures, buy a chiltons manual.
Old Oct 24, 2004 | 01:46 PM
HYBRID's Avatar
HYBRID
thanks, but id aprreciate if anyone has a link.
Old Oct 24, 2004 | 03:51 PM
LT's Avatar
LT
The deer had to die!
i put this link in the other radiator-related thread...
http://www.team-integra.net/sections...?ArticleID=763
Old Oct 24, 2004 | 06:24 PM
HYBRID's Avatar
HYBRID
thank you soooooo much
Old Oct 24, 2004 | 09:49 PM
dubcac's Avatar
dubcac
I
It's simple as hell.
Old Oct 24, 2004 | 09:53 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Just make sure you don't damage the fins when putting the new one in.
Old Oct 25, 2004 | 05:41 AM
IrishBrewer's Avatar
IrishBrewer
Fans are easier to take off after the old radiator is out. Just have to disconnect all of the fan connections.
I was suprised how easy it was to replace the radiator. Takes longer to drain the radiator than to do the rest of the job.
Old Oct 25, 2004 | 07:12 AM
LT's Avatar
LT
:werd: i've changed mine like 3 times now h:
each time it gets done faster and faster - pretty much like changing the oil at this point.
