how do you take out the o2 sensor..
Old Oct 21, 2004 | 04:31 PM
R34Lude's Avatar
R34Lude
96teg
Default how do you take out the o2 sensor..
I got under my car and was wondering how to take the o2 sensor cause it was in tight?
Old Oct 21, 2004 | 05:56 PM
fgfournet's Avatar
fgfournet
R ENVY
They make a special socket that allows the wire to stick out the side of the socket. I just disconnect the exhaust at the header and let it drop, then you can fit the socket in pretty easy.
Old Oct 21, 2004 | 07:28 PM
ricehorder's Avatar
ricehorder
This might sound silly but make sure you are turning the correct way. The O2 is upside down compared to you as you are lying on the floor. If thats not the problem try some WD-40 or equivalent thats if you don't want to buy the O2 socket.
Old Oct 21, 2004 | 11:54 PM
jjang's Avatar
jjang
when i installed my high flow cat i had to take out the o2 sensors from my stock cat. the o2 was in there tight, i just unplugged the wires for the o2 sensors (the wire for the secondary o2 sensor i just cut and left out..dont need..no emissions where i live..but u can cut the wires then solder them back together afterwards). then i grabbed my army surplus oxy-acetalene (sp?) torch and warmed up the cat where the o2 went in..yeah wd40 didnt work for me..maybe it will for u tho..it ended up being real easy to take out the o2 sensor when the metal was heated up.
Old Oct 22, 2004 | 10:52 AM
trex_tegra's Avatar
trex_tegra
i hit it with the vise grips it took a bit but i was able to get it out make sure ur turning it in the rite direction also try some penetrating lube it ill loosin it a little
Old Oct 22, 2004 | 11:52 AM
bnuk's Avatar
bnuk
haha yeah i remeber wailing on mine for like 45 minutes before realizing I was turning it the wrong way....
Old Oct 23, 2004 | 08:26 AM
fgfournet's Avatar
fgfournet
R ENVY
Buy the cheap tool, then you won't have a horror story. + you can rent it to all your friends that complain about their O2 sensor.
Old Nov 16, 2004 | 03:28 PM
ReVenGe's Avatar
ReVenGe
does it just go by, "o2 sensor rench" at pep boyz or something?
