CTR cams in GSR
Old Oct 21, 2004 | 12:17 AM
krusty990's Avatar
krusty990
Default CTR cams in GSR
Can ITR and CTR cams be installed onto a stock 2000 GS-R bottom end without piston/valve clearence problems? if no what pistons are recommended. head has been totally upgraded (springs, retainers, etc. )
Old Oct 21, 2004 | 06:45 AM
dustimus's Avatar
dustimus
Better golfer than you
:yes:
Old Oct 21, 2004 | 01:30 PM
dubcac's Avatar
dubcac
I
You'll be fine with those cams.
Old Oct 21, 2004 | 02:11 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Cams actually go in the top end with your springs and retainers in the head below the valve cover. Anyways, CTR Intake cam is preferred for and Integra, the lift is a little higher. Changing out your exhaust cam does not make much of a diffrence. ITR and CTR exhaust cams only slightly differ from a GSR exhaust cam. Go with the CTR Intake cam.
Old Oct 22, 2004 | 12:27 AM
dubcac's Avatar
dubcac
I
I think he knew that and was just making sure the valves wouldn't hit the pistons in a stock motor. That's what I got from it anyways...
Old Oct 22, 2004 | 06:55 AM
mslate's Avatar
mslate
Guys I'm new here, just got an 95 gsr. What kind of gains can be expected from just changing the intake cam?
Old Oct 22, 2004 | 01:44 PM
Snoopy's Avatar
Snoopy
been there done that
thats a very vague question. how much power you make depends on the type of cam and tuning
Old Oct 22, 2004 | 03:00 PM
ShayneBishop's Avatar
ShayneBishop
Dont Have an Integra yet
Someone told me that it would be better to put the CTR cams or ITC cams instead of like skunk2 cams..true?
Old Oct 22, 2004 | 03:07 PM
Snoopy's Avatar
Snoopy
even the skunk stage 1 is more aggressive than ctr/itr cams so what is your definition of "better"
Old Oct 23, 2004 | 05:06 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
[QUOTE=mslate]Guys I'm new here, just got an 95 gsr. What kind of gains can be expected from just changing the intake cam?[/QUOTE
If it is installed properly, expect anywhere from 50-60hp. J/K roughly a 7-9hp gain can be expected.
