96 se integra gauges
Old Oct 20, 2004 | 02:00 PM
aboobybobpleez's Avatar
aboobybobpleez
Certified Rice-Rocket
Default 96 se integra gauges
i turned on my headlights last night and only half of my gauges lit up and i could only see half of my tach and none of the temp this must be a blown bulb right? if so how do i access and replace it?
Old Oct 20, 2004 | 09:24 PM
trex_tegra's Avatar
trex_tegra
yea its gotta be a blown bulb u've gotta take the brezel off then carefully remove the gauges assembly by removing all the screws disconnect the wire harness and replace ur bulbs
Old Oct 23, 2004 | 07:31 AM
jmorales's Avatar
jmorales
Default Me too
What's the brezel? And how big a job is this? Any special tools?
Old Oct 23, 2004 | 11:39 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
It was a typo. The OP meant bezel...the oval-shaped, black trim piece that wraps around the instrument cluster [water temp, tacho, speedo, fuel, idiot lights].
A phillips-head screwdriver is all you need to remove it and the instrument cluster.
Lower the steering wheel all the way down, using the adjustment lever on the steering column. Then undo the 2 screws on the top edge of the bezel.
The bezel will then pull straight out of the dash.
This will expose the instrument cluster. If memory serves there are one or two screws on the left & right sides of the instrument cluster. Remove them and carefully slide the instrument cluster toward you. Tilt it down and disconnect the wiring harness clips from either side of the instrument cluster.
On the back of the instrument cluster - along the centerline of the panel - there are two or three lampholers; they look like little plastic knobs about 1/2 an inch in diameter (much larger than the clusters of idiot light lampholders). Turn them a half turn and they'll pull out.
The bulbs will have little blue rubber slip covers on them. Be sure to swap them onto the new bulbs. Otherwise the color of the instruments will be kind of amber, rather than a pure white.
Once that's done, swap the new bulbs in (I don't have the size, sorry) and reverse this process to reinstall the instrument cluster.
Should take no more than 20 mins.
Oh, and welcome to HAN. :cheers:
