Removing A/C
Old Oct 11, 2004 | 02:07 PM
pUrExTc's Avatar
pUrExTc
殺生丸
Default Removing A/C
Anyone done this? Need advice.
Old Oct 12, 2004 | 08:26 AM
BudMan's Avatar
BudMan
aka - dnfjeff
why? curious...I haven't done it cause it's too darn hot in Kansas
Old Oct 12, 2004 | 09:57 AM
pUrExTc's Avatar
pUrExTc
殺生丸
i actually RARELY use my A/C. Even when it's hot, window's down.
Usually, during the summer, I'm in someone else's car as it is. The Type-R is more of a weekened driver, since I have a bucket for every day abuse.
Old Oct 13, 2004 | 03:43 AM
BudMan's Avatar
BudMan
aka - dnfjeff
cool deal.
Old Oct 13, 2004 | 01:02 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
I removed mine from my GSR and it was really not all that hard. Make sure you drain the refrigerant first and then start removing the lines, compressor, etc. You will need to remove your battery and intake to do this. If you choose to remove your evaporator from inside the car you need to buy two parts from Acura (I have the part numbers at home) for about $50.00. Removing the evaporator is a real PITA and I had to take my airbag out because I did not have a deep enough socket to reach one of the bolts on top.
Old Oct 13, 2004 | 03:10 PM
pUrExTc's Avatar
pUrExTc
殺生丸
how much of a difference had you noticed after your A/C was removed?
Old Oct 13, 2004 | 07:42 PM
DVPGSR's Avatar
DVPGSR
I need sleep...
I removed both my AC and PS at the same time and on the butt dyno noticed a bit starting from a stop. But this is nothing scientific and could only have been my imagination. I also added the CTR N1 crank pulley and the biggest gain IMO was the weight loss from all the AC & PS parts that were removed. Not to mention I sold them all on eBay to help finance other mods on my car.
Old Oct 16, 2004 | 11:08 PM
IN VTEC's Avatar
IN VTEC
It's easy.
Wrap a garbage bag around the refill port and release all of the refrigerant into the bag. The bag keeps the refrigerant oil from spraying all over the car.
Undo the sockets wherever you see them (ie: under airbox, behind battery, etc.), and remove the lines as you go.
You can remove the radiator, or let it lean back to remove the condensor depending on how much room you have.
I got by without having to remove my front bumper, but I think I had my header off for other work at the same time.
