Eratic idle at running temperature.....help???
Ok here's the deal. I bought a car that has been sitting for a while. I got it all put back together and now I am having a problem with the idle.
1. When I start the car cold, it revs high at around 2000rpm.
2. After the car gets to temp the idle jumps from 1000-2000rpm.
I was thinking that it could be a EGR valve or a vacum leak but I was thrown off when I turned on the AC.
3. When the AC is on, it idles steady and fine at 1000rpm.
I have already reset the ECU and nothing helped there.
Sorry if this is a dumb question. Any info is much appreciated.
Check for vacuum leaks, and check the IAC valve.
Did you ever solve this problem? You described the EXACT symptoms I'm having with a 91 honda accord lx wagon. I sure would love to get it fixed. I don't have a manual.. so describing locations of things would help me a ton.
Check the idle air control valve, and for vacuum leaks. The IACV is under the intake manifold, vacuum hoses are self explanatory.
