This might be a dumb Question...
The deer had to die!
actually they are $11 at Advanced Auto for the 'stat and gasket. buy a gallon of honda antifreeze because you will have to drain the rad to do this install.
you're definitely loosing coolant from a leak. have you checked that the radiator end tanks are leaking (cracks on the top or bottom)? have you checked that all your coolants lines to the motor are secured and clamps are tight?
yea everything seems fine, but i might as well check again, just to make sure, the clear container on the passanger side, right next to the lights to the left, thats where the anti-freeze and water goes right?
