95 ls abs wheel sensor rr
Old Oct 1, 2004 | 06:28 AM
kevintrue's Avatar
kevintrue
farfaraway
Default 95 ls abs wheel sensor rr
hi, I am a newbie.
my 95 ls abs light is on after moving, I got the abs code 44, its right rear wheel sensor. I was told to get the sensor from Acura dealer. I am in Great Toronto Area, any idea I can get it somewhere else? and the $$$? thanks
Old Oct 1, 2004 | 06:44 AM
JimBlake's Avatar
JimBlake
www.ahmotor.com
www.acuraautomotiveparts.org
I'm sure there's others, but I don't know about shipping to Canada... You'll have to ask.
Did you check the wiring? That code doesn't guarantee the sensor's bad. Could be unplugged? Rusty/loose connection? Cut wire somewhere?
Old Oct 1, 2004 | 06:47 AM
kevintrue's Avatar
kevintrue
farfaraway
no, I did not check the wiring, will do. thanks for all the information and great suggestion.
Old Oct 2, 2004 | 05:58 AM
kevintrue's Avatar
kevintrue
farfaraway
just called the local acura dealer, Can $207 for the sensor, 1.5 hour labor, Can $132/labor hr. not a good deal, is it?
Old Oct 2, 2004 | 07:07 AM
kevintrue's Avatar
kevintrue
farfaraway
is it possible that because of the dust covering on the sensor? my tech said 99% of chance the sensor is broken.
Old Oct 4, 2004 | 07:36 AM
JimBlake's Avatar
JimBlake
I'd try cleaning it first. Take off wheel, brake caliper, brake rotor. It's sitting behind the hub, reading the notches off a toothed ring. Sometimes metal shavings stick to it, since it's magnetic.
Did you check the wiring yet?
Of course, there's a good chance it's actually bad. Buy the part & install yourself???
