Losing coolant
I replaced my radiator a couple weeks ago because it was leaking. Now I'm losing coolant. Yesterday it was below the minimum level, so I put some more coolant in. I checked the hoses, and there are no leaks or holes. Any ideas?
pull out your dipstick and check if the oil has a milky color - that would indicate coolant mixing with your oil.
are smelling coolant burning after driving? that would then mean a leak is somewhere...check that your hose clamps are tight, and maybe get a pressure check on the radiator and cap.
dom do this!
-make sure the motor is cold and NO accessories are on
-move the temp slider all the way to heat (but don't run the blower)
-pop the cap off, and fill it back up until no more bubbles down into the rad
-start the car with the rad cap off and wait until it reaches operating temperature (will take a while, have a sandwich)
-it will start bubbling, if the level drops, add more
-once it has been running @ OT for a while and the level hasn't dropped, put the cap back on
-fill the overflow to the max line
