iacv valve
Old Sep 29, 2004 | 07:01 AM
R34Lude's Avatar
R34Lude
96teg
Default iacv valve
i been having an idling problem and the ecu code i pulled out was the IAC. I took the Iac out and cleaned it. I sprayed the whole thing with carbon cleaner. It would drive regular for a couple of hours. then the rvs would gradually go up and not idle as well. Then acouple of days later the idling gets worse until i spray some more carbon cleaner. HAs anyone had this experience. Could a high purge of fuel vapor in the evaporative emission canister or valve effect this?
Old Sep 29, 2004 | 07:04 AM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
why not just replace it
Old Sep 29, 2004 | 09:25 AM
fjm1's Avatar
fjm1
G35
Default Reset
Did you reset the ecu? I've heard after cleaning idle control valve some cars run just as badly as before. some owners disconnected battery for a while solving problem.
Old Sep 29, 2004 | 12:13 PM
IrishBrewer's Avatar
IrishBrewer
If you are having problems with idling when the engine is warm, it could also be the Fast Idle Thermo Valve. It is located below the air intake connection and is held on with three bolts. Also make sure that your coolant level is good and bleed any air out of the coolant lines using the bleed valve. These idle control valves need a good flow of coolant to work properly because they depend on the coolant temp.
Old Sep 29, 2004 | 05:33 PM
R34Lude's Avatar
R34Lude
96teg
I just put in a new radiator and thermostat...that could be the problem....How do i bleed the radiator? Where is the bleed valve? Can anyone show me a picture??
Old Sep 30, 2004 | 03:55 AM
IrishBrewer
Find where the upper radiator attaches to the engine. About 2-3 inches to the right of that there should be a small bleed nipple that you can use to bleed out the air. I believe it is a 12 mm bolt. Make sure your radiator is full, put a shop towel under the valve, then loosen it until coolant starts to flow out with no bubbles.
Old Sep 30, 2004 | 05:31 AM
R34Lude's Avatar
R34Lude
96teg
Do i have to have the car at warm or can i do this when it is cold? Can you post some pics just to make sure i don't screw up...Thanks!
Old Sep 30, 2004 | 10:51 AM
IrishBrewer
OK, I'll try a pic:
You bleed it on a cool engine (not running) after filling the radiator with 50/50. Then remove the cap and fill it up again. Then run the engine until the fan kicks on, shut it off and check the level again. Thats about it.
Old Oct 1, 2004 | 06:41 AM
R34Lude's Avatar
R34Lude
96teg
Thanks for the pics..and the help i greatly appreciated..
Old Oct 1, 2004 | 07:39 AM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Does leaving the battery unhooked for a while reset the ECU??
I didn't think it worked that way.
