Help with wiring..
Ok as most of you know i had a few problems with my igition system, got that out of the way along with alot of other problems.. well here's my new one..First off this car was converted to OBDI from OBDII (97 GSR) Now the passnager side door never worked until recently when i had to rewire the whole car by myself.. i had to do alittle splicing but i matched everything up and it all works, the only thing that does not is the passnger can't lock his or her own door, but i can.. Point is after i fixed everything.. and double checked it twice.. i went a few days ago to start it up and let it run cause i aint driving it yet and i go to open the sunroof it wont open it.. i go to lock the doors they dont lock nor do the windows roll down.. but after about 3 mins they all work.. and like this morning i just went outside cranked it up to let it run and bam they all work like no problem..i did switch fuses boxes but i believe there's a short somewhere but you know the saying dont worry about it unless it stops working and it always seems to work but any ideas would helpful at this point.. also.. after it runs for awhile the fan and everything works nicely it doesn't even reach midpoint of the cool/hot temp but under the manifold where's a smell of smoke NOT ALOT.. but a scene u'd have to stare at awhile to see i believe its a coolant hose and is just decaied but i aint sure what hoses run under the manifold on a 97 gsr.. because what i can't see it doesn't affect it but its a bothersome to me the little tids bother me and i'm sure on here most of that does bother yall i just want my car to be right lol..
