ground wire
Old Sep 4, 2004 | 09:26 PM
R34Lude's Avatar
R34Lude
96teg
Default ground wire
Where can I Buy some ground wire?
Old Sep 4, 2004 | 10:43 PM
ChassisInnovations's Avatar
ChassisInnovations
HAN Authorized Vendor
All you need is 4 or 8 gauge wire, which is available at Home Depot, any store that sells car audio, etc.
-Jeff
Old Sep 4, 2004 | 11:50 PM
b00gers's Avatar
b00gers
Ground wire is simply wire that leads into a grounding point. There is not specific ground wire.
Like stated above, stores like Home Depot or car audio stores will sell wire of that gauge. I believe that OEM size is 8 gauge. But it really doen't hurt to go with 4 gauge.
You will find that if you buy a wire with more strands, they are much more flexible and easier to work with.
Old Sep 5, 2004 | 11:37 AM
94GsArrr!'s Avatar
94GsArrr!
DOHC VTEC B18C1
they sell ground wire systems on ebay
Old Sep 6, 2004 | 02:30 AM
Kai's Avatar
Kai
Rotorphile.
That's only a band-aid for someone that can't fix a stock electrical system.
I make my own new ground wires when nessicary from Home Depot parts.
Old Sep 12, 2004 | 10:55 PM
ACCORDDUST's Avatar
ACCORDDUST
ChicagoLand Accord Club
i was looking at the ones on ebay.. i might get one . is it easy to install and does it really improve performance?
Old Sep 12, 2004 | 11:52 PM
b00gers's Avatar
b00gers
It has been gone over time after time. You should do a search, ACCORDDUST. I am not trying to be an ass by saying "search nOOb!" but I am just saying that there were some really good disccussions about how well these "earthing" systems work.
But to sum it up in a few lines:
-If you can crimp, buy your own wires and connectors. It'll save you a few bucks.
-If you have a stock stereo system or if the car is not drawing more current than OEM specs, and your wiring is in decent condition...save your money and time and skip the upgrade.
-I am going to say that it DOESNT "improve" performance. I mean if your current grounds are rusty and corroded, and the connections are loose and weak; you are probably losing some power. So replacing the wiring will "improve" your performance since performance was lost due to the shooty electrical system.
-If you run a big stereo system you will want to upgrade the main wires with something thicker. Chassis to battery, alternator to battery, engine to chassis.....
