How much boost?
Old Aug 30, 2004 | 07:44 PM
Kris1212's Avatar
Kris1212
Default How much boost?
How much boost can i run in my 94 turbo GS-R w/o blowing the engine? (safely?)
Old Aug 30, 2004 | 09:05 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
w/out any internal work or sleeves and is the compression stock?
if these are the case then i think no more than 7-8 psi should be used
anymore than 9psi and you will run into problems if you dont beef up your internals
my friend has a turbo LS and he runs 7 psi w/the REVhard kit
Old Aug 31, 2004 | 07:09 PM
Kris1212's Avatar
Kris1212
I heard that GS-R's dont handle turbos well...is this true?
Old Aug 31, 2004 | 07:19 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
b18c1's have higher compression so there is more risk of detonation. With proper tuning they can handle 12+ psi on stock internals. I wouldnt push more then 7-9psi daily.
Old Aug 31, 2004 | 09:02 PM
Kai's Avatar
Kai
Rotorphile.
That depends, how good is your local shop at tuning? What kind of engine management are you running?
Old Sep 1, 2004 | 09:56 AM
kfar09's Avatar
kfar09
also, what size turbo are you running?
if its a t3/t04 then you could run 12lbs max with great tuning.
if its the greddy 18G, like i have, you could probably run a little higher since its a smaller turbo.
Old Sep 2, 2004 | 04:16 AM
SupaTeg's Avatar
SupaTeg
supa slammed
with fuel management 12-15lbs...stock internals
stock, i would go over 7...
