stiff clutch/gear shift???
Old Aug 25, 2004 | 01:30 PM
boy sicat's Avatar
boy sicat
Default stiff clutch/gear shift???
I just got a gen2 teg with a couple of mods into it and whenever I shift the gear it's a little hard to shift... so, what could be wrong with it? Thanks guys!
Old Aug 25, 2004 | 01:41 PM
carta79's Avatar
carta79
Life after death
Hows the clutch fluid? Check for leaks.
Maybe your clutch is ready to crap the bed. Also it could possibly be the pressure plate.
Old Aug 25, 2004 | 03:46 PM
newgsrdriver's Avatar
newgsrdriver
First things first, check the fluid.
If it happened after you blew through the gears, I would suggest the clutch itself or the PP.
Old Aug 25, 2004 | 03:53 PM
Laura's Avatar
Laura
simply lost
Change the Tranny fluid!
That is the first thing you should do anyway.. Change all the fluids on the car if you just got it. That way you start fresh and know exactly when these things need to be changed next time.
Old Aug 25, 2004 | 04:56 PM
acuragal03's Avatar
acuragal03
hey, when i got my short shifter installed it was really tight, but it loosened up after a while. it might just be the bolt.... h:
Old Aug 25, 2004 | 05:00 PM
boy sicat's Avatar
boy sicat
Just incase I need to change the clutch would an upgrade be better or it wouldn't do anything to the car's performance and just stay with oem? Thanks!
Old Aug 25, 2004 | 10:04 PM
acuragal03's Avatar
acuragal03
actually changing the clutch and flywheel to after market are some of the best modifications you'll ever do. you will really feel a big difference in power.
Old Aug 26, 2004 | 03:56 AM
IrishBrewer's Avatar
IrishBrewer
How does a clutch provide more power? I could see that you might get a quicker response shifting gears if the aftermarket clutch grips the flywheel faster but once it is engaged, you wouldn't be getting any more power. So are you really saying that you get a more responsive clutch with an aftermarket?
Just curious.
Old Aug 26, 2004 | 10:55 AM
rslsgsr's Avatar
rslsgsr
poor hungry dirt kid
the same thing just happen to me last nite... and now i can't go into gear without grinding... i don't know how to check the fluid.. but i'll do a lil research on that... but in my case... i might need a new clutch??? any brand i should look for? thanks... not to steal the thread but it might also help him out too.
Old Aug 26, 2004 | 11:28 AM
carta79's Avatar
carta79
Life after death
Do some research on double clutching & rev matching. It should help you some on the grinding issue. But yeah sounds like your clutch is done, or quite possibly bad syncros.
