GSR cam swap
Old Aug 19, 2004 | 02:00 PM
b18c1integra's Avatar
b18c1integra
Default GSR cam swap
I was curious as to whether I can swap my gsr cams for the integra type r cams and still be able to keep my stock gsr springs, retainers, etc. The larger lobe profile on the type r cams will not damage anything will it? How similar are the springs and retainers between the two? Any help on this would be great! Anyone on this forum looking to sell their civic type r or integra type r cams?
Old Aug 19, 2004 | 05:56 PM
shhhhhgsr's Avatar
shhhhhgsr
12.99.227.146
many will say its safe. but if you want to be reliable, then you would have to get upgraded valve springs, type r would obviously be ok. i am in the same situation, and i am just looking for type r everything, i would do the same if i were you. thats just for upgrading to type r cams.
Old Aug 19, 2004 | 06:59 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
To be safe I'd upgrade the springs and retainers as well. That's just me though...
Old Aug 19, 2004 | 07:12 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You should go for CTR cams instead. They have a longer duration on the intake cam than the ITR cams.
Old Aug 20, 2004 | 07:55 PM
GTXgp's Avatar
GTXgp
RB26 Wha?
CTR cams only differ from ITR cams in 97-99, and at that its only 3* more duration on the intake vtec lobe. 00-01 ITR & CTR are identical.
I'm currently planning out a CTR/ITR cam swap myself for my GSR. I went ahead and opted for ITR Outers and Portflow Inners with Ti retainers. Its a small investment to give me the peace-of-mind to know the springs will be doing their job after the cam swap. And I want to make sure this motor stays reliable while I build the "real" motor
Adam
Old Aug 20, 2004 | 08:40 PM
Provocateur
On permanent hiatus
Yeah not much of a difference but they cost virtually the same anyway.
Also, the valvetrain only needs upgrading if the rev limit is raised above stock.
Old Aug 22, 2004 | 01:38 PM
Snoopy's Avatar
Snoopy
been there done that
you can move the gsr stock intake valve springs to the exhaust side then use the itr intake springs.
Old Aug 23, 2004 | 04:54 AM
nc_mx_kid's Avatar
nc_mx_kid
I'm in the same boat,
I have a 95 GSR and my friend told me to put just a ITR intake cam and that would make a difference.
Should i go ahead and put ITR exhaust cam and everything????
Old Aug 23, 2004 | 08:20 AM
GTXgp's Avatar
GTXgp
RB26 Wha?
I would recommend getting ITR intake & exhaust. I don't know where you would even get just an intake cam cause most people sell em in pairs and if you're gonna do it, you might as well do it right the first time.
