Buzzing noise from engine compartment
I have air in my abs pump as well. I tried the bleeding tip posted above and it made it better. However I still get the noise for about 2 seconds when I start up the car. My ABS light pretty much stays on the whole time i'm driving.
While the sound isn't so bad the light is annoying. When I bleed it now I get no air coming out but the noise is still there.
Does any one have tips on completely eliminating this problem? I have a 95 LS btw.
You pull these ABS codes the same way you pull check-engine codes, but it's the ABS light that's blinking. Here's the sequence...
Insert the jumper, then turn on the key.
Long (2sec.) flash - long (2sec.) pause - this isn't the code yet.
Short flashes for the first digit of the code - 1sec. pause - short flashes for the 2nd digit.
Long (5-second) pause, then the next code.
(94-97) ABS DTCs...
1 - ABS pump motor over-run
1 2 ABS pump motor
1 3 high pressure leakage
1 4 pressure switch
1 8 high pressure system
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
3 12 different diameter tires
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
5 - rear wheel lock - R/L
5 4 rear wheel lock - R
5 8 rear wheel lock - L
6 - fail-safe relay - F/R
6 1 fail-safe relay - F
6 4 fail-safe relay - R
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
Beginning in '98 there's a whole different system, with a different set of error codes. The new system doesn't have it's own reservoir & bleeder.
(94-97) ABS DTCs...
1 2 ABS pump motor
1 4 pressure switch
2 1 parking brake
3 1 pulser RF
3 2 pulser LF
3 4 pulser RR
3 8 pulser LR
4 1 wheel sensor RF
4 2 wheel sensor LF
4 4 wheel sensor RR
4 8 wheel sensor LR
7 1 solenoid - RF
7 2 solenoid - LF
7 4 solenoid - R
8 1 ABS function
8 2 CPU comparison
8 4 IC self-check
Thanks for the info. I'm pretty sure that the air was not the only problem since I reset the light by both pulling the fuse and disconnecting the battery and it came on again.
I was thinking about just disconnecting the ABS period and running without it. I've never relied on ABS in my driving experience but it has come in handy on a couple of rainy and snowy conditions so I'm conflicted.
Oops, I forgot that part... Look under the glovebox, way over to the right where it goes into the kick panel. Stuffed up in that corner is a green rubber holder with 2 blue plastic electrical connectors. The green thing just holds them in place, it's not really a plug. One connector has 2 wires, other has 3. You want the plug with 2 wires, & jumper between them with a paperclip.
This is the same jumper you use when setting your spark timing & reading check-engine light codes.
Yeah, it sure is... I'll try to remember to look it up, but in the Helm book that code probably points to a testing procedure that goes on for several pages. If it's more than a couple things to check, you'd be better off getting your hands on that book. All together those checks probably take up 100 pages...
h:
